germanyt
If I glass my entire trunk so that the subs are pretty much air sealed from the cab, what kind of loss in SPL will I get? I'm unhappy with my current enclosure. It's way too small. Turned out to not be anywhere near 7.5 cubes and I just took out the crappy 4 inch port and did a 10 x 6 inch slot. It's a lot louder but due to cancellation or something I lose nearly all output when the trunk is closed. I'm probably hitting low 140s with the trunk open and in the wrong size box. I can't wait to put these SXs in the right enclosure with the port on the same plane as the sub instead of 180 degrees off. I'm expecting to hit 150 daily w/ music. That is, if glassing the trunk doesn't kill that theroy.
