That Blaupunkt amp isn't as bad as everyone says.
Is the setup loud enough for you? If it is, then what's the problem? If it isn't, you probably need to reassess your goals because an actual 75w on those very efficient speakers will make your ears bleed. It doesn't matter that you didn't hear the amp clip. Many times unless you are running it progressively into clipping with a test tone, it has to get to full clip before the distortion becomes really apparent with music. The sensory overload from the sheer volume of the sound makes this difficult as well.
