Question on FI Q's
DjiNN
Posts but still a NooB
So i have decided i wanna upgrade from my 10" MTX to 2 FI Q's 10" .... My question is would the FI Q's be good in this box this or should i have someone build me a box? .. second question would be .. What is the BP option? would it be better to get that or leave it? does it help the subwoofer? If i choose both subwoofers at 2ohms what would the load be? 1ohm? what would the load be if it was 1ohms?
yeah you should get your box built by someone
check out the SSA forum on the different options,forgot the link.
depending on your amp,which i think is 1 ohm stable, i would suggest 1 ohm, also load would be 1 ohm.
Definitely get a box made instead of those ported prefabs.
How much power are you going to be giving them? The bp option adds cooling to increase the power handling 200-500 watts (depending on application).
If you got 2 d1 (dual 1) Qs then the final load will be 1 ohm
what would be a decent amp to power these subs .. thinking fo the 2ohm load subs. For the price i think the Hifonics amp is good. Anyone have any opinions?
DjiNN
DjiNN
Brooklyn, NY
DjiNN
