Question on an upgrade....
kickerlivinloud
Banning survivor
Ok, as of tomorrow I'll be sending money for another LI. I'll be getting it from Moe and am very pumped but i am also in a little bit of a bind. I currently only have a Bahn 8001T for an amp. 800@2ohms. I will not be able to power both LI's with this amp so i plan on purchesing another amp in due time. My question is do i need to get another 8000T? Would another amp cause problems or not? Also if another amp (not 8000T) was to be used, would it have to be the same power. I know this is probably a noob question but for some reason i can't remember if one can do this. If it is to complicated i'll just sell the bahn and get a single amp to run both subs. In the end I am going to want to do whatever is the cheapest. Money is a large issue here. The only reason i'm getting the LI is b/c the price is extremely good. You help is appreciated.....
Jon
with the impendence rise that amp might run at 1 ohm, id try it. if it goes into protect, oh well //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif BTW, ill get you another box design if you want.
kickerlivinloud
Banning survivor
kickerlivinloud
Finger Lakes, NY
kickerlivinloud
