Question...Audiobahn 12” FLAME COMPRESSION SUBWOOFER
jcavz24x
Im thinking of getting ONE Audiobahn 12” FLAME COMPRESSION SUBWOOFER and a MONO audiobahn amp after i get my highs/mids.
I am doing this to save room in my trunk..Will this sound good? If so, what amp would be good.. an amp with 1,800 Watts x 1 @ 1 Ohm Mono? OR do i not need one that good??
12” FLAME COMPRESSION SUBWOOFER 280 Oz Double Stacked Strontium Magnets
Power Handling: 1500 Watts R.M.S. Frequency Response: 20Hz-500Hz
Efficiency: 91 dB PHAT 2” Multi-layer Foam Surround
Stamped and Balanced Aluminum Cone 3” 4-Layer AVS Voice Coil
Dual 2 Ohm Voice Coils 1 Ohm or 4 Ohm Operation
Mounting Dimensions: Depth; 6-3/4”, Hole; 10-7/8”, Diameter; 12-1/2” Multi-connect Lug Lock Terminals
Chris
Go with a medium sized to large ported box (around 2.5-4 cubes at least) and that sub will slap you around the inside of your car //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Im wondering if it will sound good (able to adjust?) when i play alternative type music also..do not want too much bass for songs that do not sound good with a ton of bass.
Im going to be getting infinity kappa highs/mids with an amp.
Chris
My friend has that sub in a sealed box (I think like, maybe 1.2 ft^3) powered by a A12001D 1200W (@ 1 ohm) and it sounds goooooooooooooooood. A ported box would be best for this sub, but for what you want, a sealed box will work just fine.
PS: You can get that amp off ebay for about 300 bucks new, and it's real eye candy as well as a good amp.
jcavz24x
jcavz24x
Florida
Brutus2600
