Query on VDO CD2703 Aux input
Graham Hilder
NZ
G'day all, from a newcomer to the forum. I'm no expert and I've got a little
tech query someone might be able to help me with please.
I'd like to set up an Aux input on a VDO car stereo, the VDO Daytona CD
2703.
I see the unit does have suitable AUX IN pins in one of the back panel
connector blocks, but they need to be enabled using the unit's set-up menu.
The trouble is, the CD 2703 model is one of a family of four near-identical
models, the 2703, 2803, 2203 and 2253..... they each have very slightly
different options, and the 2703 is the only one which doesn't have the Aux
In option listed in its specs-sheet.
The thing is, though, it has got the actual pins on the rear panel but the
function doesn't show up when you step through the set-up menu. I wonder if
anyone knows a way to work around this and enable that Aux In connector to
be selected? I bet somebody has sussed out a way to beat the system!
Many thanks if anyone has any suggestions,
Graham H, NZ
Graham Hilder
Graham Hilder
NZ
Graham Hilder
