Quad VC
Now, in the above pic, just pretend that two subs are a single sub. But basically you'll want to series-parallel each subs VC's (so that each sub is 2ohm), and then parallel the two subs together (for a final 1ohm load).
But, like I said, with a little imagination the above pic will work for you.
Or this pic might work for you:
You'll want to follow the same scheme as the middle sub above for each individual sub (it will give you a 2ohm load/sub), and then wire the subs together in parallel (for a final 1ohm load)
so in other words.... I hope I got this right. I will wire the power wire from the amp all the way thru all voice coils up to the last one. and end it there. And do the same with the negative side. that will end up with a one ohm load? That sounds basically what I was thinking. Hope I got it right. Thanks
joeldirt
Integrity
joeldirt
Eureka, CA
joeldirt
