PVC pipe vs Areoports
PVC pipe is just a pipe. It weight alot more than aeroports. It also doesn't sound as good as an aeroport but is "ok".
Aeroports have flare ends which is what makes them sound the way they do.
There is a difference between the two.
Aight genius, what do you think areoports are made out of ? Your right, there is a difference. The flared ends. Don't know about you, but most enclosures I build. You don't here the ports //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you will gain more spl's with flares.
you can run without flares with little to no acoustical losses. just make sure you have enough cross sectional area to get rid of any chuffage. too small, and it will sound bad. thats about it.
if you can afford flares, go for it. if not, head to home depot //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Around how many dbs would someone gain with flares
HUH? I said there is a difference in the SQ between regular pvc pipe and aeroports.
They obviously arent the same - otherwise ppl would just be buying pvc instead of paying $$$ for 4" and 6" aeros. Make your own FTW!
I understand that but you know how some people are,the go out and buy whatever the newest forum booner //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
uhhh... x3
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
no actual hands on experience, at least not with aero, i've done a few installs with pvc, never had a problem with port noise, just be sure to make the port wide ...just have to make it longer
Can one use black ABS plastic pipe ? Will it tend to crack when heated when one flares it ?
They got both at Home Depot, white PVC and black ABS plastic.
*LOL* My interior will be black so .... lol
Yeah you did.
CJL
CJL
oZone
Eldorado
