problems??
RangerDangerV2
just wondering if anyone else has these problems...
seat belt brakes lock up when the system is playing
after Im done playing my truck wont start again for a while... My guess would be that the ignition is getting fvcked up...
dash flexes like a mofo
tires shake almost uncontrollably
doors want to come off of the hinges
Ive never had a system like this before so im kind of new to all of this shiz...
anybody else have these issues?
How long have you had this system installed? a week? and so far you think you've blown your sub and messed your car up in the installation process?
Maybe put the equipment away until you're older and give it another shot
Agreed.
tire shake almost unconctrolably....doens't sound like a system problem
you're right.. Sounds like its more of a "lying on the internet in a thinly veiled attempt to "brag" about his "sweet" new setup problem.
seat belt brakes lock up when the system is playing -
this shouldn't be happening it should read defalt to the cm
after Im done playing my truck wont start again for a while... My guess would be that the ignition is getting fvcked up... -
could also be your fuel pump or severe volt drop reseting your ecm
when you are driving , under braking ? if so you would be wise to keep in mind the weight you have added to a small truck , if this an automatic S-10 start saving for a new transmission now with all that weight, just a matter of time before the low band goes out
doors want to come off of the hinges -
normal
I get your excited , but keep in mind what i said about the ****** , and keep an eye on your suspension componets ( tie rods , wheels bearings) as a word of advice with those trucks.
none of this happens while driving. tires dont shake uncontrollably, poor choice of words, but they do shake.... and im pretty sure that my ignition is broken because after a few hours of playtime I shut my truck off and now I turn the key and I have battery power but it just clicks... I checked my power and grounds so I dont know what the deal is.
and the seat belt brakes def lock up when its going full tilt as soon as I turn it down they unlock.
RangerDangerV2
RangerDangerV2
st cloud MN
wickedwitt
Mike Mccabe
