This price is for today only. $175 shipped to any of our 50 states and Canada. Take that money Santa gave you and get a hell of an amp at a sweet *** price!!
This JL 300/4 is a 8.5 - 9 Looks. and a 10 functionality wise. has a few very light surface marks on top that you really cant see unless you are looking hard. And some marks in one area from being mounted (as shown below) Cash only on this please. Here are the specs and pics.
* Rated Power(stereo): 75 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
* Rated Power (bridged): 150 W RMS x 2 @ 3 ohm-8 ohm(11V-14.5V)
* THD at Rated Power:
* S/N Ratio*: >108.5dB below rated power
* Frequency Response: 5 Hz - 30 KHz (+0, -1dB)
* Damping Factor: >200 @ 4 ohm per. ch./50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Dimensions: 13.4"L x 9.25"W x 2.36"H
* Differential-Balanced Input Topology: (2 pair of inputs)
* Front Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
* Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
* Speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
