Preventing interference from RCA cables
skatingrocker17
I know people say to run the RCA cables along the opposite side of the car that the power cables are located on. Well, the person who installed my amp (before I knew how to do it) ran them right by each other. I haven't noticed any interference but would wrapping the RCA cable in electric tape help reduce any possible interference?
I really don't want to have to to take my radio out and run the cables down the other side, it's time consuming.
I'm going to assume you are talking about a sub amp.
If its a low frequency amp with a low pass filter then you shouldn't have to worry about high frequency noise introduced threw the rca because the low pass filter will filter it out, Today's cars a lot quieter as well. I personally never run rca's on the other side unless i was doing a 4ch install.
If it ant broke dont fix it, leave it alone man lol
Will do, thanks.
I'm going to assume you are talking about a sub amp. If its a low frequency amp with a low pass filter then you shouldn't have to worry about high frequency noise introduced threw the rca because the low pass filter will filter it out, Today's cars a lot quieter as well. I personally never run rca's on the other side unless i was doing a 4ch install.
Yes it is a sub amp. I wouldn't think I would hear interference any way, even if there is any. I'll just leave it alone.
It makes no difference if you run the rca and power wire together or not. That's a myth.
don't know about noise, but it will pick up a lot of current signal from the power cable, depending on how much power you pass, and how close they are. if it's 4awg, then i don't think there is any real hazard. you ever see welding leads hop around on the floor?
skatingrocker17
skatingrocker17
Ohio
bubbagumper6
