frankiebones
i used two test tones, both at 0dB, one 50 Hz, the other 60 Hz. i did 2 trials for each, one with the HPF set at 80Hz, and the other with the HPF set to pass through since i didnt feel like putting the DMM to the subwoofer output since the RCAs are tucked deep in the trunk. with the HFP on the front output turned off, the preamp voltage readings i got from the front output will be identical to those i wouldve gotten from the subwoofer output.
the specs for my HU claim to be 5V preamp outs. i called pioneer and asked a tech support guy to inform me of which volume level the cleanest ouput signal could be achieved. he did not know, but he did tell me that the max unclipped output is 5V, and that anything under 5V should be clean.
i got the following voltage readings with all the processing I use turned on, including my EQ settings and BBE levels (i'm only providing the relevant ones, i.e., the ones up to and including the clipped output levels).
PLEASE TAKE A LOOK AT THIS GRAPH!! it took a long time to make:
http://i39.photobucket.com/albums/e164/fcelau1/graphofpreampvoltages.jpg
50 Hz / HPF On:
vol. / voltage
37- 0.395
38- 0.443
39- 0.497
40- 0.557
41- 0.625
42- 0.701
43- 0.7865
44- 0.881
45- 0.988
46- 1.107
47- 1.241
48- 1.391
49- 1.56
50- 1.75
51- 1.962
52- 2.2
53- 2.47
54- 2.76
55- 3.16
56- 3.475
57- 3.9
58- 4.37
59- 4.88
60- 5.24
61- 5.73
62- 6.08
50 Hz / HPF Off:
37- 1.049
38- 1.177
39- 1.32
40- 1.481
41- 1.661
42- 1.8635
43- 2.1
44- 2.345
45- 2.63
46- 2.95
47- 3.3
48- 3.7
49- 4.15
50- 4.65
51- 5.09
60 Hz / HPF On
37- 0.431
38- 0.483
39- 0.542
40- 0.6085
41- 0.682
42- 0.765
43- 0.857
44- 0.96
45- 1.077
46- 1.207
47- 1.351
48- 1.515
49- 1.698
50- 1.905
51- 2.14
52- 2.4
53- 2.68
54- 3
55- 3.37
56- 3.78
57- 4.24
58- 4.75
59- 5.17
60 Hz / HPF Off
43 1.76
44 1.982
45 2.22
46 2.48
47 2.79
48 3.12
49 3.51
50 3.94
51 4.41
52 4.92
53 5.28
These measurements were all taken using 50 and 60 Hz test tones. After I took these measurements, I put in the "Explosive Car Tuning CD #9", which is recorded very close to 0dB. At the levels I was going over 5V (i.e., clipping the preamp output), I still didnt come anywhere close to 5V. i think the closest i came to was 2.9V.
what do you guys think is the last unclipped volume level i should set my sub and component amps to?
again, PLEASE TAKE A LOOK AT THIS GRAPH!! it took a long time to make:
50 Hz / HPF On:
vol. / voltage
37- 0.395
38- 0.443
39- 0.497
40- 0.557
41- 0.625
42- 0.701
43- 0.7865
44- 0.881
45- 0.988
46- 1.107
47- 1.241
48- 1.391
49- 1.56
50- 1.75
51- 1.962
52- 2.2
53- 2.47
54- 2.76
55- 3.16
56- 3.475
57- 3.9
58- 4.37
59- 4.88
60- 5.24
61- 5.73
62- 6.08
50 Hz / HPF Off:
37- 1.049
38- 1.177
39- 1.32
40- 1.481
41- 1.661
42- 1.8635
43- 2.1
44- 2.345
45- 2.63
46- 2.95
47- 3.3
48- 3.7
49- 4.15
50- 4.65
51- 5.09
60 Hz / HPF On
37- 0.431
38- 0.483
39- 0.542
40- 0.6085
41- 0.682
42- 0.765
43- 0.857
44- 0.96
45- 1.077
46- 1.207
47- 1.351
48- 1.515
49- 1.698
50- 1.905
51- 2.14
52- 2.4
53- 2.68
54- 3
55- 3.37
56- 3.78
57- 4.24
58- 4.75
59- 5.17
60 Hz / HPF Off
43 1.76
44 1.982
45 2.22
46 2.48
47 2.79
48 3.12
49 3.51
50 3.94
51 4.41
52 4.92
53 5.28
