ok, i am totally happy with this HU it is awesome..
i currently have the gains set with the sub level a 0, and the deck x-over set to 120 hz.. but, my sub amp is a pg x600.1, and it not only has a quality crossover and subsonic filter, it also is not disable-able.. i have the subsonic filter set to 16.9 hz and the low pass set at 122hz..
the question is, should i be unsing the HU's crossover at all, and if so, should i open the x600.1's x-over to the max 300hz? or should i just use the amps x-over to avoind crossing it over twice? does corssing it over twice cuase any adverse side effects? or is the setting i have were they are both set nearly identicle ok? it sounds good like it is.. but i just want to be correct in setting it..
thanks
thanks
