Precision Power PPI P1000.1
06gtmike
Item(s) for Sale: Precision Power PPI P1000.1
Phantom Series Class D Full Range Monoblock Car Amplifier
RMS power Rating (14.4V):
4 ohms: 580 watts x 1 chan.
2 ohms: 725 watts x 1 chan.
1 ohm: 1,000 watts x 1 chan.
RMS power Rating (12V):
4 ohms: 395 watts x 1 chan.
2 ohms: 525 watts x 1 chan.
1 ohm: 785 watts x 1 chan.
MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Variable bass Boost (0 to +12 dB bass boost at 50 Hz)
On/Off circuit delay
Mono channel operation
Preamp rca outputs to daisy chain multiple amps
3-Way System Protection circuitry
SMT Circuitry
Composite double sided epoxy PCB
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Nickel-plated rca level inputs
Nickel-plated screw terminals
Input sensitivity:
Low level: 200mV-6V
Variable low-pass filter (40-220 Hz, 12 dB/octave)
Subsonic filter (20-38 Hz 12dB/octave)
Damping factor: >91
Dimensions: 12-15/16"L x 6-3/4"W x 2"H
Item(s) Description/Condition: Works perfect and in good cosmetic condition. Comes in the original box with the adapter and bass knob
Price: $150 shipped to the continental US. No trades at the moment
Shipping and Miscellaneous Item Information: Included
Sounds great and puts out some power for such a small amp (it is tiny but pretty heavy for its size). As far as 1200 i'm not sure, i don't do any clamping but it does have 120 amps of fusing so it's probably a little underrated at 1000.
06gtmike
06gtmike
Williamsburg, VA
john_doe_318
vegang
vegang
