precision port
I'd like to add that necessary port area is dependent on how much air you will be moving, so cone area alone is not enough information. If your talking 4kw and 50mm of xmax then you'll likely need more port than either of your options offer. However, in most scenarios 2 6"ers should be adequate.
Specifications
FS 44.7 HZ
RE 3.6 OHM
QMS 9.63
QES 0.412
QTS 0.395
RMS 11.05
CMS 0.0334 MM/N
MMS 378.26 G
BL 32.14 TM
SPL@1W 91.83 DB
VAS 37.83 L
XMAX 15 MM
XCOIL 55 MM 55 MM 55 MM
as for amps two gp3000d
JOHNJOHN485
JOHNJOHN485
KENNER, LA
169db
