ppi pcx 4ch and mono block
SCIVIC94
if it isnt broke,modify
up for sale is a set of ppi amps
one is a pcx 480.4 4 channel asking $250 shipped obo
one is a pcx 1500.1 2 channel asking $350 shipped obo
both amps have some scratches . both were fully functional when removed from from my old car.
I will accept payments via paypal or usps money order only.
details are
pcx480
Power Bandwidth 10 Hz - 50 kHz
Total Harmonic Distortion > 0.02 %
S/N Ratio
Input Topology Instrumentation
Input Sensitivity 150mv - 12 Volts RMS
Input Impedance 10k Ohms
Load Impedance (stereo) 2 - 8 Ohms
Load Impedance (bridged) 4 - 8 Ohms
Supply Voltage 11 - 15 Volts
Damping Factor > 500
Slew Rate > 50 V/μS
QBASS™ Up To +12dB @ 40Hz
QBASS PLUS™ Up To +18dB Boost
@ 30, 36, 44, or 60Hz
Crossovers 12dB/Octave
Crossover Frequency 30-4kHz
Idle Current: PCX 480 2.5 Amps
suggest using 70 amp fuse
power ratings
MODEL 4ohm STEREO 2ohm STEREO 4ohm MONO
PCX 480 4 X 80 4 X 160 2 X 320
Length Height Width
18.50” 2.375” 10”
PCX 1500
Power Bandwidth 20 Hz - 20 kHz
S/N Ratio > 110dB
Load Impedance (mono) 2 - 8 Ohms
Slew Rate > 50 V/μS
Subsonic Crossover Frequency 5-80Hz
Idle Current: PCX 1500 2 Amps
suggest using 100 amp fuse
power ratings
4ohm MONO 2ohm MONO
1 X 500 1 X 1000
* ALL POWER RATINGS SHOWN ARE TESTED @ 12V; 20-20kHz
Length Height Width
25.00” 2.375” 10”
SCIVIC94
SCIVIC94
ELIZABETH , NJ
SCIVIC94
