PPI PC650 enough power for modest system?
That amplifier is doable BUT your install technique will play a larger factor than you would think! For example, your subs will probably need to be installed in a larger than usual ported enclosure that is tuned relatively low to produce more bass from less power. The only downside I could potentially see is issues with your 8" mids/midbass in that it (ETA 50 watts per mid) may not be enough to blend everything together. Then again, I tend to always end up picking horribly inefficient drivers that need gobs of power, so maybe you will get lucky.
The next pitfall I see here is that you appear to have 8 speakers and only 6 channels of power. Don't tell me you are going to be forced to run something... *GASP*... passive when your goal appears to be more SQ oriented.
thanks for the response....yes .....the 2 way is set up to run passive....
this is about what I figured....end result may not be enough power....
I guess I will need to hook it up and see...I was just looking for users of the amp to tell me how they liked or disliked it.
gentlejax
gentlejax
Bossier City, La.
gentlejax
