8 is only good for 50 amps at 20 feet. Good 8 that is. Cable is a choke point so it needs to be as large as possiblThat's something I don't under stand is why ppl use the 4 gauge amp wire instead of the 8 since it is only 600 or so watts I thought 8 gauge was good up to a certain amount of power
hey,if the whole is big enough....imma cram it fullThat's something I don't under stand is why ppl use the 4 gauge amp wire instead of the 8 since it is only 600 or so watts I thought 8 gauge was good up to a certain amount of power
to properly power use the jl audios becasue the infinities youll have to wire to 4 ohms. and the jls to 2 ohms so youll get power out of the amp. or run a single infinity speaker at 2 ohms in a proper custom box built to subs specs.Ok got another ? I also have a pair of jl audio 12 wx 4ohm svc which of the two sets I have would yall use all opinions welcome
