PPI DCX 1000.1 Question.
PiDiZzEl
Mike Jones is gay.
Not sure if anyone is familiar with this amp or not. Currently I have it wired at 1 ohm. I want to do four. I have 2 Dual 4 ohm subs. I'm aware it's not possible to wire the subs together for 2 ohms, but it is if each sub is wired seperate. The DCX has 2 positive terminals and 2 negative terminals. If i wire each sub differently, will i have 300 watts going to each sub (600 watts total), or 600 to each sub (1200 total).
Amp ratings.
400x1 + 4 ohm
600x1 + 2 ohm
1000x1 + 1 ohm
No.
The internals of the amp as CJ said, are split at the out puts so you dont need to jam a bunch of speaker wires into only one terminal, its just for convenience it is not an actual left and right channel.
Read this tid bit I wrote on how ohms work so you get a better Idea what to do.
http://www.caraudio.com/vb/showthread.php?t=108646
PiDiZzEl
Mike Jones is gay.
PiDiZzEl
Pittsburgh, PA
cjjackson85
