ppi ba5000.1d, ppi ba7000.1d 2 ohm rating?
xiang
NY
Does any ones know if the 2 ohm ratings for the ppi ba5000.1d and ppi ba7000.1d is correct The Ppi ba5000.1d puts out more at 2 ohms?
ppi ba5000.1d
Black Ice Series Monoblock Class D Car Amplifier
RMS Power Rating:
4 ohms: 1200 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2500 watts x 1 chan.
ppi ba7000.1d
RMS Power Rating:
4 ohms: 1000 watts x 1 chan.
2 ohms: 1500 watts x 1 chan.
1 ohms: 2300 x 1 chan.
0.5 ohm: 3500 watts x 1 chan.
Thats good to know. What numbers did you get when you tested those amps? Any recommendation on an amp that will do 1,500-2,000 rms @ 2ohms?
Wouldn't waste money on testing them but I am sure they have been benched by someone do a search... Budget?? I assume cheap as u are looking at these?
Im thinking something around $800. but if i can find something cheaper that puts out a good amount of clean power i would go with it.
the 7000 put out around 2500w with battery voltage, itd be closer to 3k at 14.4v. but that was wired low with a burp, you might get 2k out of it on music with a half ohm load
yup that right.
it puts out good power. helll it ripping my truck up . i have the 7000 on a hdc3 15"
i like it, worth the money.
but if you have 800 to spend on a good amp, i want a sq 2200 amp.
http://www.soundqubed.com/Q1-22002_p_31.html
or you can get the bigger one for 800.
i want to get all sq amps. right now i have 1 and love it.
so if you want to spend the least get the ppi 7000 . if you want better for more look into the sq amps.
tbh id probably get a crescendo bc2000 before the sq, but sq is a lot more promoted by people on this forum so its really a matter of opinion.
all the top names are good, just depends on what you want and how much money you really want to spend.
i recommend ppi and sq because i use them and they do me good for the price.
in saying that, if i had money i would be getting some dd stuff.....
If I had the money I'd get some Genesis amps //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
xiang
xiang
NY
ThatChevyGuy
