Ppi 900.4
cal
ppi class d 4chanel
Phantom Series Class D Full Range 4-Channel Car Amplifier
RMS power Rating (14.4V):
4 ohms: 145 watts x 4 chan.
2 ohms: 225 watts x 4 chan.
Bridged, 4 ohms: 450 watts x 2 chan.
RMS power Rating (12V):
4 ohms: 100 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
Bridged, 4 ohms: 300 watts x 2 chan.
MOSFET power supply
LED power (green) and protect (red) indicators
On/Off circuit delay
4/3/2 channel operation
3-Way System Protection circuitry
Tri-mode capable
Band-pass crossovers
Input source selector
SMT Circuitry
Composite double sided epoxy PCB
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Nickel-plated rca level inputs
Nickel-plated screw terminals
Input sensitivity:
Low level: 200mV-6V
Variable high-pass filter (20-4000 Hz, 12 dB/octave)
Variable low-pass filter (50-5000 Hz, 12 dB/octave)
Damping factor: >114
Dimensions: 10-15/16"L x 6-3/4"W x 2"H
4-gauge power and ground wiring is required for installation.
used but fully working . amp has some hair line cratches by the top because its palstic , kinda looks like swirl marks . also byu the wires scracthes from screw driver due to design of amp , not noticeable when mounted see pic # 1754. amp is a beast never been repaired or gone into protection
includes is the adapter to run 1/0 guage wires
150 shipped in the u.s.
cal
cal
cal
