Powering a Fosgate P2 or P3?
joegeek
I am getting a great deal on a Punch 300.1 amp and have decided to get 1 12" RF sub for my trunk.
I can get a RF P2 12 for $98.00 or a P3 12 for $149.99.
Will the Punch 300.1 power either one well?
Also, is it true that since I listen to rock/metal music only that 1 sub is best?
the punch 300.1 amp will power the 12" RF p2 best because its rated at 250 so a little more power will be good for it. the p3 is wanting 500 and 300 will be weak. not saying u cant do it but i wouldnt pay the extra money if ur not going to use the subs full potential.
i have 2 subs and they sound great with metal but they are SQ subs where RF is not that great in that category
OP, it'd be best if you'd spend a little more time looking around. I help people put together budget systems nearly every day, so you can shoot me a pm if you like.
I'll point you in a much better direction...
Ok thanks for the help.
Would SQ matter as much sitting in my trunk facing the rear?
If u have not heard a good SQ subwoofer before u probably wont even notice its bad. i had some rockford p2s and i was amazed at the output. then i got my polks and i wont buy RF again.
You shouldn't limit yourself to Polk subs....and you shouldn't be using a Rockford Fosgate P2 as a measuring stick.
There are plenty of subs that put both to shame...
Okay ill recommend subs ive never heard and ill also ignore my real life experience of subs that i have heard in real life and disregard those.
Is that what ur asking me to do?
Will do, u probably know best.
Wasn't speaking to you, homie.
But I do know quite a bit. I've been doing this stuff for a long while.
Nobody said you have to give your valuable advice either. You mad bo?
well i dont want to recommend something bad but OP check this link where people who have the polk mm series subs, some have 8, 10, 12, no one has said anything about the 15" yet though but they all have good stuff to say.
Polk Audio MM subs - DIYMA.com
if u can afford Image Dynamics go for them at least i wont get flamed for suggesting those
joegeek
joegeek
Southern Ohio
Cruzer
