Sold powerbass xa3000d
flores210
i am selling my powerbass amp because i want to buy a digital designs z1 amp or something comparable but this amp just got a new board put in it by powerbass and hasnt been played since it only came in yesterday but i am looking for 400 OBO since i paid that just to get it fixed due to a repair guy cracking my board on it and a 3 month wait just to get it back lmk thanks
Specifications
* Remote Bass Control (Included): Wired dash mounted remote allows you to fine tune the amps special BASS EQ circuitry. Variable from 0~18dB.
* Strap Two Amps Together for Double Power Output: Allows two of the same model amplifier to be combined in a Master/Slave configuration to function as one for increased power.
* Oversized Power and Ground Inputs: Heavy duty 4-Guage CNC machined high efficiency Power and Ground Inputs for maximum power transfer.
* 24 dB/Octave Electronic Crossover: Variable LPF (Low Pass Frequency) from 20Hz~1.5KHz plus a separate variable Sub Sonic filter for maximum system flexibilty.
* Self-diagnostic Protection Circuitry: 4-way protection circuitry guards against Short Circuit/Thermal Overheating/ Impedance Overload and DC Output
* 4 ohm Power : 1000W x 1
* 2 ohm Power : 2000W x 1
* 1 ohm Mono Power : 3000W x 1
* Strapped Power : 6200W
* Total Harmonic Distortion :
* Frequency Response : 10Hz - 400Hz
* S/N Ratio : >90 dB/W/M
* Damping Factor : >200
* Input Sensitivity : 0.3 - 8.0 volts
* Crossover Slope : 12 dB
* High-Pass Crossover Freq : 50Hz - 250Hz
* Effective Piston Area -Sd: 480 cm^2
* Variable Subwoofer EQ : 0/+18 dB
* Subwoofer EQ Frequency : 45Hz
* Dimensions : 20.87" x 10.51" x 2.56"
* Dimensions : 530mm x 267mm x 65mm
BOUGHT FROM FIERYWINTER
REFS-FIERYWINTER,VTOWNDJ,wprivateer,usadt23,iliveforbass on CARSTEREO.COM
No kidding, if I had the green I would, Having a hell of a time trying to sell the good gear I have //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
free bump for PowerBass Good stuff!
If I had something you were looking for I would offer up in a heartbeat.
Good luck!
flores210
flores210
southside
flores210
