powerbass xa3000d vs. audiopipe 3000
powerbass is a power hog as is the ap3000d which only runs at 2 ohm
mmats is really the only amp company you might get away running stock for 3000 watts cause of there 120v rails
Audiopipe AQX3500.1 3500 Watt RMS Class D Mono 1 Ohm Stable Amplifier :: Car Audio Deals
this is a much better audiopipe amp, same as the rd audio 3250v2 much better build class d so more efficient. but like i said your going to need electrical, what type of car you have sometimes you can get a cheap ebay alternator
on a stock elelctrical, you are going to beable to do nothing. esp in the 3krms range. maybe 1000 maybe 1500 but not 3k. you will destroy every amp you get within a month or 2...
The man speaks the truth you need a h.o alt and at least 1 batt in the trunk for 3k.
the audiopipe's protection won't kick in until you go under ~1.3 ohms as I am told. At a local meet we tested the ap30001d vs the pb3000 and AP was more efficent and put out more power. But if you have stock eletricals and wanted to run at 1 ohm, you should go with the pb3000 because its rated to do 3k at 1 ohm. Ap3001d is rated to do 3k at 2 ohms.
Mr Bojangles
Bullhockey
Mr Bojangles
H'burg MS
Corey J.
