Power wire unplugged, but active?
tractng
Guys,
Tonight I was replacing my fuse holder near the battery. I unplugged it from the positive (+) terminal and lay it on top of a piece cloth.
Later I accidently moved it and contacted with a piece of metal and a "spark" occurred.
Shouldn't it be a dead wire (not active)?
Tony
static? Same thing has happened to me before...I was screwing down the pos. terminal on the amp, and when I went to screw down the gnd, I got a spark from the screwdriver.
It would seem to me that there doesn't neccesarily need to be current in the lead you disconnected to produce the arc / spark. As long as it was grounded, or connected to something that was grounded, completing that circuit could cause a spark.
Wire-welding hurts. : )
* re-read post. Depending on what metal it touched (Alternator? Frame?) Perhaps you've got a short somehow. If you expected the metal it touched to be neutral/ground, i'd voltmeter it to make sure your frame isn't charged. If it's any other electronic component / alternator? then I suppose that would explain it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Where's the foot in mouth smiley? I'm posting this anyway =P
I've noticed after removing the fuse from the power wire, that a voltage reading only slowly decreases....e.g., once you remove the fuse, there's still some electromotiveness up in that wire.
tractng
tractng
Los Angeles
sumone
