Power wire fuses?
SnowCommando
Picked up a Pioneer GM-D7400M Mono Amp to run my sub.
The wiring diagram in the manual shows a fuse holder at the battery and says Fuse (40A) x2.
Any ideas what they are specifying? Do I need to somehow run two 40A fuses or an 80A fuse? Or do they just want me to use a single 40A fuse and have a spare 40A fuse around.
The mono amp has 2x25A fuses in it.
I'm also running a 4 channel amp which has 2x25A fuses in it. It uses a 30A fuse in the power wire.
I'm using 4ga wire to a fuse holder near the battery.
4ga to a fused distribution block to 8ga into each amp.
Any interpretations on the 40Ax2 would be appreciated.
There is one fuse in line right after the battery than another in the amp. OR it could be talking about 2 fuses already in the amp. Mine has 4 fuses in the amp.
EDIT Ya I looked in the manual and I see what your are looking at its just the fuse at the battery and no you don't need 2 fuses.
Cool. Thanks for looking. It seemed super weird to have 2 fuses at the battery. I'd rather find out now though than watch the amp detonate.
I wonder why they say 40Ax2 then?
Some types of fuses are not made larger than 40A. If you use ANL style fuses, you can get them as high as 750A.
SnowCommando
SnowCommando
Australia
loopkiller
