Power Acoustik REACT1-1800?
302yota
this amp shows it's ratings x1 channel...but on the amp it is showing 2 separate channels.....if i were to run a dvc 4ohm sub in parallel at 2 ohms, after wiring it to the amp on the mono mode....would it drop the resistance down to 1 ohms, or keep it at 2...(since it is a so called monoblock)
it claims it's a mono amp...but if you actually look at the amp it has two channels, so if you were to bridge it, would it take it down to 1 ohms...or keep it at 2, with it being a "mono" amp
302yota
302yota
rockingham, NC
302yota
