power acoustik pw315H
They are the biggest paper weights in the world. I say good luck to you. They have dual 2 ohm coils that are 2.5" in diameter. I hope your friend simply gave the woofer to you and did not require monetary reimbursement, otherwise it would have been a complete rip off.
2600 watts max (900 watts continuous)
PolyPro injection molded dome cone with laser etched design on cone rolled foam sourround and dual CONEX spider
160 oz. magnet with 2 1/2" aluminum voice coil plus ABS motor cover and ABS plastic gasket
Stamped steel basket with integrated tinsel leads with nickel plated push terminals
7 1/4" mounting depth
joshua.lee.ford
joshua.lee.ford
Dawson Springs, KY
allout13
