dilligaf241
trying to decide on a comp amp for a budget system i'm puttin together. the two i'm lookin at are these
Power Acoustik ps4-480
840 Watts of Power (Max)
Number of Channels: 4
85 x 4 RMS @ 4 Ohms
110 x 4 RMS @ 2 Ohm
High pass, Low Pass, By-Pass Crossovers built in (adjustable)
Three Way Protection Circuitry
Tri-Mode Capable
Full Mosfet Power Supply
High/Low Level inputs
4 Gauge Power / Ground Connection
Gold plated RCA Connectors
Line output
PWM Circuitry
18dB Bass Boost @ 40Hz.
Frequency Response: 10Hz to 30Khz
S/N Ratio:97 db
THD: 0.02%
Dimensions (WxHxD) 14-1/2" (W) x 11-1/4" (H) x 2-1/4" (D)
or profile baja ha740
Peak Output Power (4 Ohms) 120W x 4
RMS Output Power (4 Ohms) 60W x 4
Peak Output Power (2 Ohms) 175W x 4
RMS Output Power (2 Ohms) 90W x 4
Bridged RMS Output Power (4 Ohms) 180W x 2
MOSFET Power Supply Yes
Total Harmonic Distortion
Signal / Noise Ratio 100 dB
Pre-Amp (RCA) Outputs Yes
Variable Bass Boost at 45Hz 0/6/12 dB (Ch 3 & 4)
Treble Boost at 8kHz 0/6/12 dB (Ch 1 & 2)
12dB/Octave Crossover
(High Pass/Full/Low Pass) HP/Full (Ch 1 & 2) Full/LP (Ch 3 & 4)
Variable LP Crossover Frequency 50 - 250 Hz
Variable HP Crossover Frequency 80 Hz - 1.2 kHz
Fuse 40A
Dimensions (2 1/4" H x 9 11/16" D) 11 3/16" W
which one is the better quaility of the two? closer to true power rated? gonna be powering all pioneer 5.5 speakers. thanks for any help.
85 x 4 RMS @ 4 Ohms
110 x 4 RMS @ 2 Ohm
Tri-Mode Capable
Line output
PWM Circuitry
S/N Ratio:97 db
THD: 0.02%
Fuse 40A
