Power Acoustik/Kole Audio 5500d testing!
uptwome2007
I was told by the tech over at power acoustik that the Power Acousitk BAMF 5500d and the Kole Audio Phanatik 5500d are the same amps. Both carry 5-40 amp fuses and the specs are the same on paper. I did some testing in my car using the Kole Audio 5500d, here are the results..........................................
Voltage drop after 5 seconds - AC Volts - Amps - Imp Rise - Watts
15.91 - 57- 20- 2.85- 1140
15.0 - 54- 42- 1.28- 2268
15.44 - 55 - 45- 1.22- 2475
The first two tests were done using 1 Power Master 16 volt battery, and the last test was with two Power Master 16 volt batteries. The batteries are the power master S1000's. It doesn't put out the rated power, but still not bad for a budget amp. I also tested it against power acoustik's well known a3000db, and the kole 5500 is definately stonger. One big difference between the a3000db and the 5500d is that the 5500d will take up to 18.2 volts before going into protect and the a3000db will go into protect at 17.2 volts. I'll do some 12volt testing and post results later. Just thought I'd share my results for those that were wondering like me.
The most I got at 15.44 volts was 2475 watts. That was with a 1.22 imp rise.
Oh wow.. Really... I was hoping for more //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
So I could probably hope for barley 2000........
Is ~00.15$ a watt good?
Did some more testing at 16 volts...........................
Dc voltage dropping to 16.3 volts
AC volts.........................62
AC Amps........................56
Impedance Rise.............1.10 ohms
Watts.............................3472watts
uptwome2007
uptwome2007
new jersey
Engine_hp
