Power Acoustik 3000 Watt
I've had the a1800db for a year and a half now and it has never given me any problems, I've also installed a 2400db and two a3000db's, very solid amps and reasonably priced.
They seem to work well. One of the crawl-thru boxes I did in a Ford F150 xcab about 6 months ago had 4 of the 3000db's on a pair of DD 9515's and this guy runs his system one click below clipping at 1ohm nominal per amp ALL DAY LONG. Seriously, the guy listens to 150dB worth of 29-40Hz stuff everywhere he goes. They have not failed him yet. $300.00 is fairly cheap for the level of output and reliability that those amps seem to have.
That amp is rated for 1.1kW @ 4 Ohms.If the amp is somewhat of an underachiever do you reckon that might be around 900w or so? (@ 4 Ohms?)
Following this line of assumption (which is all it is at this stage until someone confirms or denies my suppositions) would y'all reckon it does around 450w @ 8 ohms?
A friend of mine has a project planned wherein he'll need an amp for the DVC 4 sub that he already has. I was thinking if my guessed figures are anywhere near accurate he could spend $300 and have plenty of juice for his single 12" DAT CM3 with a whole bunch of room for future system growth.
If it's as reliable as you guys are saying then I can see it being a worthwhile investment for him now.
Jared530
Drop bombs
Jared530
Sacramento, Ca
DBfan187
