potassium perchlorate
but hey swimfreak. I have a question. Have you ever succesfull detonated NC? Because ive tried to make a large enough AP cap to set it off, but it didnt. What do u suggest?
If by NC you mean nitrocellulose, yes, I've done it successfully.
You can actually detonate it rather easily, with a match or a model rocket igniter for example. There are two things that I can think you're doing incorrectly if you're having trouble detonating. The first is that I noticed your recipie used way too little nitric acid. If you're not completely nitrogenating the cellulose that the activation energy will increase and you'll have trouble detonating...so try a bit more concentrated nitric acid solution (1:1 or 2:1 sulfuric to nitric).
The second thing that may be going wrong is that you've got acid residue in the compound. This can be fixed my extended rinsings (5-10 washes isn't excessive), and prolonged drying time afterwards.
yea the rinsing isnt the problem, i dedicted a whole day to rinsing the cotton. Ok ill try using more nitric acid. I dont mean igniting it, i mean detonating it. make it blow up not flare.
yea the rinsing isn't the problem, i dedicated a whole day to rinsing the cotton. Ok ill try using more nitric acid. I don't mean igniting it, i mean detonating it. make it blow up not flare.
It needs a reason to blow up. Just like gunpowder, all it does it burn rather quickly. The only way to make it "explode" is to have it enclosed in something. I'm struggling to describe this right now...
think of a firecracker....the only reason it explodes is that the trapped gas from the burning of the powder has to blow out the side of the thing...were you just to have the powder, it'd burn similar to what you're experiencing.
Jared530
Drop bombs
Jared530
Sacramento, Ca
swimfreak26
