Possibly a new sticky??
create a sticky for this?
  • Yes
    Votes: 6 75.0%
  • No
    Votes: 1 12.5%
  • Make noobz figure it out
    Votes: 1 12.5%
  • Total voters
    8
snfsh79077
Ladie's like my pole
I'm about to switch to one set of comps and push 200wrms to them. I dont remember which size speaker wire I have running throughout the truck. I'll be double checking that later but my idea for a sticky would be to list the power capabilities of each size of speaker wire and which size is best to run when pushing x amount of power. This would apply for speakers and subs. I'd never thought about it but I don't know the answer to the question.
So I think it could be a helpful sticky to come up with. Agree?
so this is what Im getting from this program:
speaker wire:
runs equal to or shorter than 10ft @ 4ohms
14g up to100wrms
12g up to 250wrms
10g up to 400wrms
runs up to 20ft @ 4ohms
14g up to 75wrms
12g up to 150wrms
10g up to 250wrms to 300wrms
sub wire:
all runs set at 5 feet
4ohms
14g up to 400wrms
12g up to 750wrms
10g up to 1500wrms
8g up to 2500wrms to 3000wrms
2ohms
14g up to 300wrms
12g up to 500wrms
10g up to 1000wrms
8g up to 2000wrms
1ohm
14g up to 150wrms
12g up to 350wrms
10g up to 1000wrms (speaker will only see 980wrms)
8g up to 2250wrms (speaker will only see 2227wrms)
.5 ohm @ 4ft
10g up to 500wrms (speaker will only see 480wrms)
8g up to 1500wrms (speaker will only see 1470wrms)
most of these calculations are what would seem to be the best conditions but each could be pushed more but will have a greater wattage loss and higher amperage flow
someone check this because it doesn't seem all that right.
thats a tough call because there are a lot of variables, such as impedence (as you've shown), but also wire length is a big one. I'm running 10ga speaker wire for my system now due to really short wire lengths, but my last setup (less wattage) i used 8ga.
then again, the sticky could always estimate a bit high?
i vote yes either way tho i guess hah
snfsh79077
snfsh79077
bay st. louis/baton rouge
snfsh79077
