Tiger Bass
Im not sure 100% if it was my amp, but chances are...it was.
Setup in sig
I was going down the road listening to Tech Nine - Get Blowed. I was by no means bumping it to its max, but it was going pretty decent. I had only been listening for about 5-10 minutes when this happened. The amp was no where near overheated. The only thing different from usuall was that I had changed up the equalizer a little bit, trying to get a little more SQ. Then all of a sudden the speakers make a small pop (most noticeably the front ones). The headunit also shut off at the same time, cutting out all the speakers. I then smelled a slight burning smell then it quickly passed. I went right back to my dorm so I could check it out in hopes that it was just a fuse for some d@mn reason. Pull all of them out, nothing noticeable. I then start the car back up to see if maybe the amp went into uber protection mode, amp light not coming on. Im going to go down to Wal-Mart much later tonight to get a set of fuses and replace them all for just in case I missed a blow but I looked them over pretty good. How would I check to see if the amp itself is blown? I only mention the song because I think it was ironic that I blew something to "Get Blowed".
Long Story short:
-Heard a small pop then headunit turned off. Came back on after a couple seconds but no bass
-Smelt a small electrical burning smell but nothing smelled once I checked everything out
-Amp is not getting power any more
-Headunit and front speakers still work
-Checked all fuses and none appear to be blown but Im going to change later to be safe
-Need to know how to physically check the amp to see if its dead
Setup in sig
Long Story short:
