Port tuning on a 18" DC Level 4XL
Z from Japan
I am looking for suggestions on port tuning (recommended Hz) for a 18" DC Level 4XL D2 pushed by a US Amps Merlin MD2D 1500W@1ohm.
This will be going in the back of my family van and I have about 6-7cubes (maybe 8cu if I am willing to give up more trunk space) to work with.
This will never be metered. I just want to rock on out to some old school Techmaster PEB, Bass Mechanic, etc. FWIW, I like the lows //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
What is a good frequency to shoot for to make this sound good?
Here are the subs specs:
Mounting Depth 9.25"
Mounting Hole Diameter 16.75"
Motor Width 8.75"
Weight 56.5lbs
VC Diameter 3" Flat 8 layer
Magnet Weight 50lbs
Power Handling RMS/Peak 1500/3000
Impedance D 1 or 2ohm
Sd 1159.00 cm²
Fs 31.86Hz
Qms 7.25
Qes 0.33
Qts 0.31
Xmax 26mm
Sensitivity 94.77
Suggested Sealed N/A
Suggested Ported 5.0³-8.0³ ft
I have a DC Level 4 18 tuned to 32hz, it def likes the lows, but sounds good on everything. The upper end suprised me too.
30hz would be a little better on the lows, and 6.5 cubic feet net would be a nice size for that sub.
^^Thats very encouraging to hear. It means a lot and I am looking forward to seeing what this can do.
Just two hypothetical boxes, the outter dimensions would be similar:
one is 5cuft tuned for 28hz,
and the other is 7.5 tuned for 32hz.
How much different would they sound?
I realize that the bigger box would be more efficient (louder) off lower power, but the one tuned for lower hz might have a smoother and deeper roll off.
Anyone have any suggestions on these two boxes?
If you had to choose between the 2 then without question go w/ the 7.5ft3 @ 32hz setup. The other box is just all wrong in more than one way.
Def agree with you on that, however, my box was 5.5ft3 at 32hz and sounded great. I considered a larger box to dig those lows a little better however. Even with the low tuning, the sub would honestly benifit from a larger enclosure esp on the lows.
Z from Japan
Z from Japan
Okinawa, Japan
WOT
