Port Questions
Devil Tiger
My subs manual says
3 x 12.5” (7.6x31.8cm) port, 20.5” (52.1cm) long
Power Handling = 300W RMS
5 ft^3 + port displacement
for a 12" vented enclosure. The enclosure I'm designing is pictured below for two subs. Do I double the port dimensions? This seems uber small for how big the box is. I used another web sites calculator (PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES) and it says when I enter my port dimensions "you should use a width:height ratio of less than 1:8" (with dimensions 3"x33.5", volume of 5ft^3, 35hz tuning freq).
If I change the dimensions to 3"x24" it will do the calculating and say the length should be 12.68".
So at this point I'd like to know what is my designs current tuning freq (I'm aiming for 35hz) and if I need to downsize my current port.
My current designs net volume (with port and sub displacement subtracted out) is 4.89 ft^3. The external dimensions are 35"x14"x27".
http://www.kicker.com/sites/default/files/2007CompVR.pdf
http://i.imgur.com/mdb28.jpg
Before starting a thread about proper port dimensions, use the search feature. I dont care if you said you did, you obviously did not. THOUSANDS of people have commented ont he "golden rule of thumb" for ports. 12-16 in^2 per CUBIC FOOT. take the recomended cubic feet for your subwoofer, lets say 2ft^3. yyou need a minimum of 24in^2 of port area for the box. if you are doing two, you would double the port area. now with the port area in mind factor in the size of the port you can fit into your size restrictions. if you can not fit a proper size port either a) get new smaller speakers or b) go with a sealed box (which i prefer due to personal preference)
So in the current design that would be 33.5"x10"? Which is over 300 in^3...way too big right?
no, you have 33.5"x3"= 100.5" height x width which is still far to big.
Devil Tiger
Devil Tiger
Southern Illinois, United States
Devil Tiger
    Jun 24, 2026
    Jun 24, 2026
