port location???
RangerDangerV2
now, i am starting on a box for 5 sa8's.... I have everything figured out except for the placement, quantity, and size of ports..... I have an extended cab ranger, box is in the back and the center console is out... I was planning on 2 four inch external aeros firing between the two front seats where the center console used to be.... Is this a bad idea??? subs are facing directly upwards.. going for a 35 hz tuning.
subs forward/port up....I've tried every possible way really in an ext cab and that seems to work the best
I posted this in your thread yesterday, but this is my old box for 5 sa8's
what length for a 35hz tuning... i plug it into a calculator and it says that for a 3.0 cu ft net enclosure the ports would have to be 37 inches long...that doesnt seem right???
well I would like to stick with aeros because the precision port ones are cheap and they are a lot easier for me to install than a slot port.... will two four inch aeros really lower my output that much???
and I dont know how you got a 32 hz tuning with that port because the port calculator tells me that a 5 inch wide by 9.5 inch tall slot port would have to be 55.6 inches??? please educate me:confused:
that port isn't 5" x 9.5"......not sure the exact length but it goes down the box, then comes back up
I don't design boxes so I can't help with the port size/length , I had someone do that one
RangerDangerV2
RangerDangerV2
st cloud MN
bhsdriller
