port forwarding???
In the preferences in bitlord it should have some kind of "connection options." In there it should have a port for you to choose, usually it's best to pick a higher up non-common port for bittorrent. Then, you go into your routers setup page and go to port fowarding and set xxxx-xxxx port to be fowarded to the IP of your machine.
doesnt really matter the port, so long as its nto being used by anything else. so just use port 65005 and u should be fine. and yes on bitlord im talkinga bout the listening port. depending on what router you have, will depend on what settings u change on your router. me, i use a linksys.
tEh koRnDog
tEh koRnDog
Buffalo, NY
MikeofTulsa
