port diameter????????????????
  • 4
3inch min for 10inch sub, 4 inch would be better.
4inch min for 12inch sub, 6 inch would be better.
6inch min for 15inch sub, 8 inch would be better.
two 3's close to one 4 inch in area
two 4's close to one 6 inch in area
two 6's close to one 8 inch in area
seems about right to me.
i think 50 in^2 of port area for two 12's is pretty standard. that's what i'm going to do for a slot port. i think that comes out to 4, 4" round ports and i've seen a lot of people doing that too.
which is about the same as two 6's, which is what I said was a good choice :p
dunno, ima start building on 2 boxes
one has 4, 4" ports all ports 13" long, if you plug a port it will tune lower.
10" sub 11w 12.5h and 25d @ 3cu.
4 open 55hz
1 pluged 47hz
2 pluged 39hz
3 pluged 28hz
i like this idea cause you can use it for comps or daily instead of a slot port were its set at one freq and you cant really change it.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
726
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
900
879
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
jeeper07
Rebuilding&Reconstruc ting
jeeper07
Indianapolis, IN
jeeper07
audiobaun
    May 19, 2024
    May 19, 2024
