big nick
I need help with my sub it keeps on giving me a popping sound my setup is 2 12 inch l5's 600 rms each total of 1200 rms subs are wired down to 2 ohms powering them is a lightening audio 3000md does 1100 rms @ 2 ohms i have 4 gauge from battery to amp then 12 gauge from the amp to the subs and the subs are wired down to 2 ohms with 12 gauge everything was bought brand new not even 6 months ago subs were properly broken in and the gain on my amp isnt even up a quarter of the way everything else is down not using bass boost and the bass settings on my headunit are set to 0
every so often i will get a loud popping sound from the subs ... i believe its only one of the 2 but im not sure the sound almost sounds like someone knocking on wood i dont smell anything burning and theres no smoke
i was thinking that the problem was my voltage dropping was somehow sending a clipped signal so i was going to do the big 3 and throw in a hc800 battery in my trunk
has anyone else had this problem or know what it is/a way to fix it?
Thank you
Thank you
