popping noise????
Also check your remote wire, and make sure it's hooked up to the proper wire coming from your deck.
pretty sure it is, used the same remote for a different amp and it worked fine.
low voltage can cause that. quick check with a dmm will tell you.
pretty sure voltage wasnt low, but can check was i get back to collage tomorrow since the dmm is there
poundindak69
monroeton, pa
poundindak69
