Any clue on how to resolve this? It said to use the same remote wire as the amp..which didn't help. Would a capacitor help? Sorry I'm purdy ignorant of this.
sounds like you need a delay relay.. processor is shutting off before the amps.. However, that is odd for a processor to do, most of them have a turn on/off delay.
Turn-on / Turn-off pop is caused because your amplifiers are remaining on while your 3Sixty is either turning on or off. Both your amp(s) and 3Sixty need to utilize the same remote turn-on. If they are on different circuits or some use a relay and while others come direct from the source unit or auto-antenna turn-on, you will have issues. Also, the manual incorrectly states that the B+ connector on the
3Sixty and Remote should be connected to a switched 12V source. It should state that the B+ should be connected to a constant 12V source instead.
