vario
digidash hit the gas...
I have a 3 cubic foot box with a 6 inch pvc port. How much polyfill should I put in?
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7168&mode=threadedI have a 3 cubic foot box with a 6 inch pvc port. How much polyfill should I put in?
No. Polyfil is not what you need. You need more port area or a flared fort. I would suggest either using 1 flared (aero) 6" port or use about 4 4" PVC ports. Make sure to recalculate the length that is needed for your tuning.will it reduce port noise? certain songs, especially pink floyd's on the run cause the port to fart
Thanks I really appreciate it. I expected the 32hz waves in that song to cause that but its good to have it clarified as I'm not much of an engineer.No. Polyfil is not what you need. You need more port area or a flared fort. I would suggest either using 1 flared (aero) 6" port or use about 4 4" PVC ports. Make sure to recalculate the length that is needed for your tuning.
Oh and the reason that song causes port noise is because it is very close to your tuning. That song has some 32hz material in it that will really cause the port to oscillate and so you will get port noise if you don't have enough port area.
