polyfil + ported box.... help
maldecido33
MSEE
I've got a box right now (a custom built truck box) for two 10"s that's sitting at .95 cubes per sub after sub and port displacement. I need to get this number up a little closer to 1.3-1.5 cubes, and the only way I can think to do this is by using polyfil, as I have the dimensions as big as they'll go. Now, since this is a ported box, I need to know **** near the exact Vb of the box in order to properly tune it.
My question is, how do I know how much exactly polyfil will add to my box; or, more specifically, how much polyfil to add to gain half a cubic foot of volume.
Or, any other alternatives to making the box bigger? The ports are already partially external.
All polyfill does is slow down the backwave coming off the subwoofer, so it takes longer for the soundwave too come back and hit the back of the cone, so the sub "acts" like it is a larger box
I heard something, it may not be right but 16 ounces of polyfill= 1 cubic foot
Any (small) gain you get from the "bigger box" effect of fill will be more then negated by the damping effect of said fill, you'll actually loose peak output by at least 3db.
If the box sounds boomy and you want better SQ then adding some fill is a suitable approach.
If you want more output you can strike fill off the list now.
maldecido33
MSEE
maldecido33
Lubbock, TX
Shyne151
