Poly Fill work?
Bad idea if you get any moisture in that door. The polyfill will get all moldy and start to stink to high heaven. I used some in my car to dampen vibrations between the rear parcel shelf and the frame. It worked well for but that is a dry place.
Polyfill doesn't do quite the same thing deadener does...the point of sound deadening is to mass load the surface by simply adding weight to the panel - reducing its tendency to vibrate and lowering its resonant frequency.
What I'm trying to do is to both increase response by killing noise, i guess. Wahtev, i can do it later, back to wiring tweets into the pillars //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
LoudCrownVic
1/1 of Team Team Team
LoudCrownVic
Scales Bump, IL
LoudCrownVic
