POLL, 2.67ohm load on a 4-ohm bridged 2ch amplifier?
Can a 2ch amp making 600RMS bridged at 4 ohms handle a 3 ohm load of 600RMS?
  • Yes
    Votes: 8 80.0%
  • No
    Votes: 2 20.0%
  • Total voters
    10
Supergumby5000
Project: F350 begins...
Im going to be putting a substage in my girlfriends car. I had her look at some subs, and she wants three kicker CVR 8s.
Now before i go buy another amp, i have a hifonics 2ch amp here (ZXI6006, 600RMS bridged @ 4 ohms)
I figure 3 dual 4 ohm CVRs wire into a 2.67ohm load. After taking into account impedence rise and whatnot, im wondering if the 2ch amp will be able to take a 3-ish ohm load
I understand wiring a 2 ohm stable amp down to a 1 ohm load is 95% of the time a no-no, but a 3ohm load compared to a 4 ohm load isnt too much more stress is it? Considering the wattage isnt horrendous and her electrical system wont be stressing.
Take a vote, can i get away with it?
is it possible to wire 2 subs to one channel and one sub to one channel so the ohm loads are right
if not you should be able to get away with it after rise should be close to 4ohms
yes, but im not doing that. subs would see different amounts of power
Im thinking the amp should be able to handle the load no problem, but i just wanna make sure nobody has had a bad experience with this type of situation
how is that so if the amp does say 300x2 at 2ohms and u wire 2 subs to one channel to do 300rms to both so 150rms to each of the 2 subs and wire the 3rd sub to 4 ohms if the amp does 150@4ohms then its perfect or just set gains with a dmm or o-scope to send equal wattage to each sub
Supergumby5000
Supergumby5000
Pullman, WA
Cbass
