Polk SR124 DVC
  • Thread starter Bigr
  • Replies 0
  • Views 967
Bigr
Anyone heard of this sub or used one??? I will be running 400 watts to each Voice Coil in a vented box. Polt recomends sealed, but I was bent on going vented, any sugestions would be appreciated.
Pics will follow tomorrow...
HeDriver Complement
Woofer 1 - 12" Diameter (30.48cm)
NBR (Nitrile Butyl Rubber) Surround
Electrical
Overall Frequency Response 20-200 Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 700 w
Power Handling (peak) 1400 w
Efficiency 89 dB
Driver Mounting Depth
Top Mount 7-3/5" (19.30cm)
Theile/Small Parameters
Resonant Frequency 30 Hz
Qms 8.0
Qes 0.6
Qts 0.55
Vas 53 Liters
Cms 150 Micro Meters
Bl 19 series Tesla Meters
Sd 499 sq. cm / 77.35 sq. in
Xmax (linear) 16.25 mm / 0.64 in
Xmax (mechanical) 63.5 mm / 2.5 in
Mms 183 g
Driver Weight 26.5 lbs
Other
Product Weight 26.50 lbs.
re are the specs.
Bigr
Bigr
Bakersfield, Ca
Bigr
