PLZ GIVE ADVICE: 3 Legacy 12's, 2000 peak, with Legacy predator amp, 4000 if bridged
Ok so Im lookin to buy 3 Legacy 12's. 1000 watts rms and 2000 watts peak. Then im wanting to buy a Legacy predator amp. its a 2 channel 4000 watt Bridgeable MOSFET amp.
2000 watts x 2 output
4000 watts x 1 bridged output
I am planning to bridge the amp to all 3 subs... Will this work?? and will it sound good??
Im buying these subs and amp of of Teptronics.com
Would 15's be better than 12's???
SPECS::
12" subwoofer
Red Chrome Plated Injection Cone
Non-Fatiguing Butyl Rubber Surround
Chrome Plated Back Plates
Dual Magnet Structure
Dual 2'' High Temperature Kapton Voice Coil
Bumped and Vented Yoke
4 Ohm Impedance Per Coil
1000 Watts RMS/2000 Watts Peak
SPL @ 1W/1M: 88dB
Frequency Response: 30Hz-1.5KHz
Mounting Depth: 5''
Magnet Weight: 100 + 100 oz.
AMP
2000 Watts x 2 Output
4000 Watts x 1 Bridged Output
Variable Hi/Lo Electronic Crossover Network
Variable Bass Boost
Variable Input Level (Gain) Control
MOSFET PWM Power Supply
Power ON LED Indicator
LED Protection Indicator
Remote Bass Boost
Hi/Lo Impedance Input
Thermal / Overload / Short Circuit Protection
Anti-Thump Turn-On
Dimensions: 1.97'' H x 11.42'' W x 21'' L
denning12591
denning12591
Auburn, Kentucky
denning12591
