please help with my box
  • 2
slipknot87420
^^^^^^420^^^^^^
ok i have a box for 2 12s and its 1.25 per sub i have 2 4in by 12in ports here are the specs for the sub
fs 38.1 hz
vas 63.1 ltr's
qts o.38
qms 10.13
qes 0.4
xmax 4mm
re 3.49ohms
sd 64.3in2
cms 0.25x10-3
mms 2.43oz
spl 91db
vc dia 2"
what do i need to tune it to i was thinking around 33 what is it tuned to now? with 2 4inx12 ports please help
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Well tuning at the level you guys are talking about is over my head at the moment. I built this box with 4 different chamber sizes so I could hear...
19
3K
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
970
slipknot87420
^^^^^^420^^^^^^
slipknot87420
huntsville alabama
ChefJoe
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
