please help w/ polyfill
  • 3
94gmsierra
canada
do you honestly stuff this stuff in any which way?? i mean doesn't it melt and stick to the sub. or get caught up in it?? i know its a lb/cu. foot but it just seems odd. i want to use it to try and slow the harshness of the bass i get w/ some music
You just fill a sealed box with it. for ported boxes you line the box with fiber sheets. It doesnt melt but it can get cought in the sub. Just stuff it in larger pieces. Surround the sub but dont over stuff it.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
956
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
94gmsierra
94gmsierra
canada
slick rick
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
